2.0E Heared On 2.2 Bottom
mantaboy89
Built a 2.2 motor but can't sort fueling system was going to fit a 2.0e head with single Webber 32/36 carb and 2.2 cam, is this going to drastically reduce the performance of the motor or should it be ok, not chasing massive power just want a cheap manta build out this month, so have to do it with what I have, will eventually run twin s.u carbs, any help on this subject much appreciated.
2.0 head on a 2.2 is ok. Comp ratio will actually be slightly higher as the 2.0 combustion chamber is smaller. If your using a Weber just use the matching cam from a 2.0 otherwise you will need to get it set up to get it running right. Use a 2.0 dizzy aswell.
Hth
Chris
