TJM Posted May 15, 2014 Share Posted May 15, 2014 (edited) Hello I have the following bits for sale: AP Racing Brake Kit (For 15" Wheels) consisting on CP5040 Pro 5000+ calipers, AP Racing 304x28mm Discs, DS2500 Brake Pads, Brake Bells And Brackets, AP Racing Bell To Disc Mounting Bolts, Caliper Mounting Bolts, Shim Washer. £1250.00. SOLD SBD 7 Degree Bellhousing - Only Ever Been Used For Dry Building - Vauxhall 8V/16V Redtop Etc To Ford Gearboxes Type 9 etc With Bolts £135.00. SBD 7 Degree Inlet Manifold With Water Tube - Only Ever Been Used For Dry Building - Vauxhall Redtop 2.0 16V - Studs And Carb Seals Included (Some O Rings Are Missing) £100.00 Chevette/Kadett C/Manta B/Cavalier Mk1 Lower Wishbone Bushes - Fitted To A Wishbone Then Removed To Be Replaced By Poly Bushes - Never Been Put Onto A Car £25.00 a Pair. Chevette Inder Lens - Secondhand £5.00 SOLD Chevette Indicator Lenses NOS £25.00 A Pair. SOLD Chevette Indicators - Secondhand £20.00 A Pair SOLD Chevette Indicators - Secondhand £20.00 A Pair SOLD Jenve 45 Throttle Bodies - Secondhand £250.00 A Pair SOLD Quaife NOS Ford Type 9 Gear Lever With Nylon Gearknob - Some Slight Surface Rust And Finger Marks On Gearknob - Only Ever Used Ford Dry Builds - £70.00 SOLD Chevette/Kadett C/Manta B/Cavalier Mk1 RoseJointed Rear Axle Links - Standard Converted By MW Motorsport - Rear Bush Housing Strapped For Strength - Needs Rear Bushes (Not Supplied) £50.00 A Pair. Postage Extra at cost. I can accept PayPal at no extra charge. More to come soon included new Progressive Chevette HD Front Springs. Regards Tim Edited May 24, 2014 by TJM Changed the image links into images Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 15, 2014 Share Posted May 15, 2014 (edited) How much to post the Bell housing XE to type 9 please. Also, does it take a standard type 9 release arm. THanks Edited May 15, 2014 by Sutty2006 Quote Link to comment Share on other sites More sharing options...
TJM Posted May 15, 2014 Author Share Posted May 15, 2014 £10.99 to UK Mainland for everything except the Brake Kit which would be nearer £20 with insurance. Regards Tim Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 15, 2014 Share Posted May 15, 2014 Cheers. Does the bell housing take a standard type 9 release arm? Quote Link to comment Share on other sites More sharing options...
TJM Posted May 15, 2014 Author Share Posted May 15, 2014 (edited) It will be worth you having a read of the following link, go to the bottom of the page. I don't think the Type 9 one will suit. The SBD one looks like a RS2000 one? http://www.sbdev.co.uk/Clutches/Clutch_Release_Mechanisms/Clutch_Release_Mechanisms.htm Regards Tim Edited May 16, 2014 by TJM Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 15, 2014 Share Posted May 15, 2014 cant see a description bud. Just a picture. Quote Link to comment Share on other sites More sharing options...
TJM Posted May 16, 2014 Author Share Posted May 16, 2014 Sorry, have now put the link in. It gives a small description but basically saying Ford made so many variations it is difficult to identify which ones will or will not fit. Theirs does but as I say it does look like a RS2000 lever. Regards Tim Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 17, 2014 Share Posted May 17, 2014 Cheers Tim will pass the message on Quote Link to comment Share on other sites More sharing options...
devilwoo Posted May 17, 2014 Share Posted May 17, 2014 Excuse me for the lack of knowledge, how do throttle bodies work? Quote Link to comment Share on other sites More sharing options...
TJM Posted May 18, 2014 Author Share Posted May 18, 2014 These ones are replacement for weber dcoe or dellorto dhla carburettors. They convert to fuel injection, are programmable with the correct ecu etc, more efficient, more reliable than carburettors. Regards Tim Quote Link to comment Share on other sites More sharing options...
TJM Posted May 24, 2014 Author Share Posted May 24, 2014 More items sold, please see amended list above. Regards Tim Quote Link to comment Share on other sites More sharing options...
Derek e Posted January 12, 2018 Share Posted January 12, 2018 Hi there do you have any of the second hand Chevette indicator units still available. thanks in anticipation Quote Link to comment Share on other sites More sharing options...
TJM Posted January 12, 2018 Author Share Posted January 12, 2018 All sold now. Regards Tim Quote Link to comment Share on other sites More sharing options...
