opelmantagsi Posted June 24, 2014 Share Posted June 24, 2014 Looking to replace mine while I rebuild the doors. Either need two complete new ones or the part number so I can track them down Can't make out the part number on the OMOC DVD scan of the microfiche. Link to comment Share on other sites More sharing options...
paulmanta Posted June 24, 2014 Share Posted June 24, 2014 Tried this, could not find any. Rebuilt mine in the end, I took them out of the doors, bent the tabs that hold them together, stripped out the plastic, rubber and little metal rollers and cleaned it all up. Then I put new metal rollers in because the ones in had flat spots, I think they were mm steel bar so I put 5mm stainless bar in cut to size and put them all back together with grease. Work a treat, cost was about an hour and some odd bar I had hanging around. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted June 25, 2014 Share Posted June 25, 2014 If you will need help the 127mm link is available Link to comment Share on other sites More sharing options...
opelmantagsi Posted July 1, 2014 Author Share Posted July 1, 2014 (edited) if its the same as this then it should be ok (but a new one ) Edited July 1, 2014 by opelmantagsi Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted July 2, 2014 Share Posted July 2, 2014 This is a complete link with base that you request It is available only at Adam Opel AG at 66,32 Euros per item + delivery costs...sorry Link to comment Share on other sites More sharing options...
opelmantagsi Posted July 2, 2014 Author Share Posted July 2, 2014 Ordered from Opel parts Greece. 1 Link to comment Share on other sites More sharing options...
opelmantagsi Posted July 17, 2014 Author Share Posted July 17, 2014 top service from OPEL PARTS GREECE Part number is always good to know. 1 Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted July 17, 2014 Share Posted July 17, 2014 More than glad to hear satisfaction........ 1 Link to comment Share on other sites More sharing options...
