Polo Conversion Heater Fan
It shouldn't be the back of the motor hitting the plastic air intake part on the ones i build if the above conversion fits without touching.
I shorten the motor shaft and tuck the motor right up to the back of the impeller, the jubilee clip is almost at the rear of the motor body without spacers between the brackets and mounting ring so there is a lot less sticking behind the mounting ring than in the above pictures.
One of the problems with the original position in the polo is that water gets through the air intake and into the heater housing inside the car, unfortunately the lowest point inside the heater box is where the resistor sits.
