i2000 Posted May 5, 2015 Share Posted May 5, 2015 hi,i am looking for the 2 front seatbelt guides that go in the rear quarter panel interior cards,the letter box shaped bits of plastic that the seatbelt goes through,i have got a broken one,part number gm 90045613.thanks. Link to comment Share on other sites More sharing options...
Tetris Posted June 23, 2015 Share Posted June 23, 2015 I´m also looking for this hard to find little pieces. Tell me if you find some Link to comment Share on other sites More sharing options...
Fermanta Posted June 23, 2015 Share Posted June 23, 2015 Hmm.....how do you remove belts without breaking them? I had to remove a belt & ended up splitting it to remove lol, sure there is a way but I hadn't time & got frustrated.... Link to comment Share on other sites More sharing options...
Tetris Posted June 24, 2015 Share Posted June 24, 2015 I don´t know. Mine fell apart, they where very dry and brittle. So if I found new ones Idon´tnow how to put it back Guess I have to make a Little crack somewhere it doesn´t show. Link to comment Share on other sites More sharing options...
Julian Posted June 24, 2015 Share Posted June 24, 2015 The original ones have a split in them, they have to so that you can put the belt in, which you do before fitting them into the side card, they are springy enough when new but tend to get brittle over the years and will crack, and you end up with two pieces., when I read your post I thought that I had a pair of them, but after I started looking I remembered that I gave them to another member a couple of years back. Link to comment Share on other sites More sharing options...
rusty321 Posted July 4, 2015 Share Posted July 4, 2015 If I remember correctly arn't nova ones the same just thought there might be more of them around than manta ones Link to comment Share on other sites More sharing options...
Tetris Posted July 9, 2015 Share Posted July 9, 2015 I found some like this, I bought more if there is someone else in need. They cost 50 SEK each about 3,80 GBP Link to comment Share on other sites More sharing options...
