yeti132 Posted June 25, 2015 Share Posted June 25, 2015 Does anyone no where I can get some shims that fit in the rear axle which go in just before you put the rear drive shaft in fit up next to the rear bearing Quote Link to comment Share on other sites More sharing options...
611 Posted June 26, 2015 Share Posted June 26, 2015 Do you want the half shaft shims or the pinion bearing shims? Andy Quote Link to comment Share on other sites More sharing options...
yeti132 Posted June 26, 2015 Author Share Posted June 26, 2015 The shims that go in where before the drive shaft so the drive shaft sits flush up against the axle Quote Link to comment Share on other sites More sharing options...
