Thebishop Posted May 11, 2016 Share Posted May 11, 2016 Hi I have just noticed this yesterday and today on both attempts to start car it just clicks twice and then starts. Do I need a new starter or what? Regards Ross Quote Link to comment Share on other sites More sharing options...
Snowy Posted May 11, 2016 Share Posted May 11, 2016 Check the earth strap between the body and engine first. I use a good quality jump lead or a spare good earth cable . Quote Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted May 11, 2016 Share Posted May 11, 2016 Check that the battery is fully charged. If the battery is fully charged and the starter still clicks a couple of times before turning over it could be that the brushes in the starter are almost worn out and it's sticking. If you find that the starter sticks completely, a tap on the side casing with a hammer can sometimes free it up and allow you to start the car. Ultimately you can either replace the brushes or the starter motor if that is the problem. You can usually find reconditioned ones on E-bay at a reasonable price. Quote Link to comment Share on other sites More sharing options...
Thebishop Posted May 11, 2016 Author Share Posted May 11, 2016 Thanks lads for all the help much appreciated. Quote Link to comment Share on other sites More sharing options...
