Redtop engine
Thebishop
Well lads after all my talk and options I finally purchased a Redtop engine 2.0 16v.
so with the engine I got wiring loom and ecu , so what else do I need ?
I have the 1.8 engine already fitted.
All help and advice greatly appreciated .
Regards.:thumbup
Regards.:thumbup
You will need a rwd redtop exhaust manifold (Ashley for a cheap one or Retropower for a good one) and a suitable clutch (I believe Kevin Abbott is your man)
Use sump, engine mounts and gearbox from the 1.8 and drop it straight in :thumbup
If you're going to stick with the dizzy mounted on the back you will need to remove your heater box. Either that or I think it's a MK1 Astra GTE dizzy you can use mounted on the front with a bracket (again Kevin Abbott) run off the cam pulley with a short belt.
I removed the Manta heater and fitted a Polo heater box to clear my dizzy, quite a common conversion.....
Edited by biffy1984
More info
Mine's a 1.8 tank, I just drilled a hole in the sender and soldered in an 8mm pipe for the return. I used the original feed pipe, mounted the fuel pump outside under the back seat and ran a wire straight to the ecu. It's a piece of piss, get the engine in the hole and sort the tank/pump etc after.
You will also need spigot bearing to put in the crankshaft end, fwd don't use them but rwd does.
For the tank you would be better off sourcing a GT/e coupe tank as they have a larger bore outlet to feed the injection and a swirl pot built in to keep a constant supply of fuel to the pick up.
Polo heater is a very tight fit and only just clears dizzy, have a look at the micro-heater options out there for kit cars and the like. Quite a few people have used them in mantas now so worth a read of some of the forum projects.
