MSGManta Posted November 22, 2016 Share Posted November 22, 2016 My driver's side door pull handle or (flap) has snapped off the door, pulled it too hard, a complete door may be considered instead. Also need driver's side door rubber weather seals which fit to the body and not the door. Link to comment Share on other sites More sharing options...
plumster Posted November 23, 2016 Share Posted November 23, 2016 (edited) You should be able to get a replacement handle, someone on here will have a box full somewhere.. is it the plain black type? Fitting is fiddly but easy enough. (must be I've just put new ones on mine) Or are you after the internal handle? Edited November 23, 2016 by plumster added a bit. Link to comment Share on other sites More sharing options...
