rear diff manta a or b from 1.6-2.0 (3.44 ratio best, 3.67 if not)
andy1023
Rear diff needed.
Ideal the 3.44 ratio one from a 1.8, 1.9, or 2.0 but would consider one from a 1.6, 1.8, 1.9 or 2.0 with the 3.67 ratio if I can't get a 3.44.
It's got a newer 2.0 SEH 8v engine with 5 speed box so not sure if 3.67 will be OK or not? I know 3.44 will be. Any advice on this welcome!!
But might just need to take what i can get anyway..!
I'm needing all internal diff gears including crown gear and pinion worm gear. My half shafts and diff casing and axle are OK so think any manta a or b or similar the same diff inside. Daft for me to take a whole axle unless someone doesn't have time to strip a diff for me I could consider an axle just a bit much to courier..!
I'm in Glasgow happy to do courier or maybe collect depending where, travelling a bit in next while..
Thanks folks.
The 1.8 had a 3.67 standard.
2.0 SEH will be fine with the 3.67 setup thats what i ran in mine with the same engine. You get better acceleration with a 3.67 but will be a few hundred rpm higher cruising at 70. It isn't so low that you will ever get to the rev limiter in top gear either.
