Ascona b Diff.
taylorblue5
Hi Folks.
My Ascona is originally a 1.6 car and the pinion bearing went and on changing it the pinion was damaged.
I replaced the pinion and crown wheel with a 3.44 from a Manta and the end of the pinuon has snapped trying to take up the play in the shaft for preload.
Is my diff different to that of a Manta is the question im asking??
My 1.6 Ascona B had a smaller axle on it than the Manta ones. I swapped the whole lot for an 1800 Manta one, then built a ZF diff into it. I had to borrow a tool called a Torsionmeter to set that preload and bought a new crush washer from Dr Manta. You need to make a special spanner out of a spare torque tube driveshaft too.
