clivecoupe Posted January 23, 2018 Share Posted January 23, 2018 DOse anyone know if the out put from my 2L XE red tops coil pack/ distributorless ecu will work my manta rev counter?! and if so what pin it is?! Cheers Clive Quote Link to comment Share on other sites More sharing options...
Manta hatch Posted January 24, 2018 Share Posted January 24, 2018 Yes will work fine it's the green wire on one of the three plugs next to Ecu if u still have original green black and brown plugs it's the only solid green wire connects to half moon plug on manta/ cav 6 dials will have green and brown white (brown white could be wrong ) but the green is definitely rpm gauge and the other brown white am sure is hand brake light hope this helps Quote Link to comment Share on other sites More sharing options...
