Manta GTE Temp Gauge or Instrument Cluster reqd - SORTED, thanks
rutthenut
The temperature gauge in my Manta doesn't work, so anyone got a replacement gauge, or a full instrument cluster I can dismantle and use?
Sourced what I need, thanks
Edited by rutthenut
No longer required
Are you sure its not a voltage reg, someone made new ones years ago, think they control oil pressure, temp, and voltage. Fuel is seperate! I think?.
You can also swap out each gauge.
Tbh, if your rallying V8, i would mount two gauges in centre consule, two in centre air vents. Temp, fuel, oil pressure, voltage.
Edited by ®evo03
Have checked and other gauges work fine, though aware voltage reg can cause problems too.
Now sorted replacement gauge (and will just swap over the single item within the dash cluster).
V8 died, along with front end of the car, so being rebuilt/reincarnated with a V6 and new MSUK log book, giving 10 years validity for rallying in new spec, as V8 won't be permitted in future years.
Centre air vents are for air. I do have a panel below that which I had put other gauges into before.
Thanks
