Trooker Posted May 27, 2019 Share Posted May 27, 2019 2.0 CIH LE Jetronic I don't normally hammer a cold engine but she'll rev fine until she's at normal temp and then its a bit like a rev limiter around 3000. It seems to be electrical as I can stop for 5 mins then she'll go to 6000. I've previously changed the coil, ECU and metering head, tonight I finally had a chance to change the occasionally noisy fuel-pump as it really feels like a lack of fuel but despite the change she's still the same. Starts instantly from cold, idles at around 8/900 rpm which is low but fine. When warm needs the throttle about 1/3 way down to start quickly or she needs a bit more of a grind. Also when warm the idle is apt to be nearer 1200 rpm but a blip of the throttle will bring it down but that may be a red herring... Anyone else had this? Quote Link to comment Share on other sites More sharing options...
