Courtenay T 27 Posted May 16, 2020 Share Posted May 16, 2020 (edited) You think your getting close, then Bammmmm In need of a front timing case cover for my 2.0e 1987 block.. I have been using the frontera for the crank sensor wheel and crank sensor to use DTA engine management. The casing has just broke off where the oil feed pipe for the Turbo comes out of it. Hopefully a standard Manta cover will be able to take the frontera crank pulley and oil pump base (for the crank sensor to be mounted) Edited May 16, 2020 by Courtenay T 27 Incorrect description Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 16, 2020 Share Posted May 16, 2020 I think I’ve got a spare you can have. Will check and get photos tomorrow. 1 Link to comment Share on other sites More sharing options...
Courtenay T 27 Posted May 17, 2020 Author Share Posted May 17, 2020 14 hours ago, Sutty2006 said: I think I’ve got a spare you can have. Will check and get photos tomorrow. You are a star Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 17, 2020 Share Posted May 17, 2020 Is this what you’re after? Link to comment Share on other sites More sharing options...
Courtenay T 27 Posted May 17, 2020 Author Share Posted May 17, 2020 Yes!! 😁 Link to comment Share on other sites More sharing options...
