glenshane Posted June 10, 2020 Share Posted June 10, 2020 On my A series manta I fitted Weber carb with the standard breather the two vents on the rocker cover one is already connected back into the breather can the smaller one also be turned into the breather either by drilling an extra hole or using a T to join into larger pipe . Or should it just vent down side of engine into a separate catch . Quote Link to comment Share on other sites More sharing options...
rutts Posted June 11, 2020 Share Posted June 11, 2020 Small pipe goes just below carburettor its an emissions thing. Quote Link to comment Share on other sites More sharing options...
glenshane Posted June 27, 2020 Author Share Posted June 27, 2020 Thanks rutts while crawling underneath the car I spotted where the pipe plugged back into on the manifold below the carb. Its hidden from sight behind the servo pipe . Quote Link to comment Share on other sites More sharing options...
