cam.in.head Posted April 15, 2021 Share Posted April 15, 2021 hi. i put a wanted ad on a while back for a top mounting block for the front axle but cannot seem to add a reply to my post ? basically, someone did say they may have one soon and i cannot remember or find that reply ?.? if your reading this( whoever you are !) il be ready for one in the next month if you have it available now please. its the square block with the long upright bolt that bolts up through the front chassis. must be later one piece type and nice and supple to match a nearly new one i already have. many thanks. 1 Link to comment Share on other sites More sharing options...
stumpy Posted April 16, 2021 Share Posted April 16, 2021 (edited) hi mate i beleive thats me my chassis should be finished by the end of next week i can then remove the subframe to remove it... i only need one to use as a pattern the ones ime going to use are machined aluminium blocks with a recess on the inside for the bolt uless anyone can give me the dimensions Edited April 16, 2021 by stumpy Link to comment Share on other sites More sharing options...
