Neilm Posted May 3, 2023 Share Posted May 3, 2023 Lost my speedo...cable seems fine both ends and pulled the inner cable out/ greased and replaced. It doesn't turn when the car is driving so seems to be a gearbox end fault. I can see the yellow (19 tooth) end of the drive gear sticking out of the gearbox...but couldn't remove it... I wanted to check the teeth...how to remove it? (1.8s Engine and box are fitted in my 1951 riley rma...drives great!) Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 3, 2023 Share Posted May 3, 2023 its just held in by a 10mm bolt on a little flat piece. should just pull out as a whole unit. held / sealed by an o ring. Quote Link to comment Share on other sites More sharing options...
