john hibbert Posted May 29, 2023 Share Posted May 29, 2023 replacing front panels and could do with this measurement thanks Quote Link to comment Share on other sites More sharing options...
611 Posted May 29, 2023 Share Posted May 29, 2023 If i can do it with the bumper on i can sort that out for you tomorrow. Do you need it from the top of that front panel to where it ends, or from the top to where the valance curves under? or both! Andy Quote Link to comment Share on other sites More sharing options...
john hibbert Posted May 29, 2023 Author Share Posted May 29, 2023 evening Andy where ever you can get a measurement from its difficult with the bumper on i understand its so i get the lap of the two panels correct before welded up thanks Quote Link to comment Share on other sites More sharing options...
611 Posted May 29, 2023 Share Posted May 29, 2023 1 hour ago, john hibbert said: evening Andy where ever you can get a measurement from its difficult with the bumper on i understand its so i get the lap of the two panels correct before welded up thanks Hey John Let me see what i can do and will get back to you tomorrow. Andy Quote Link to comment Share on other sites More sharing options...
611 Posted May 30, 2023 Share Posted May 30, 2023 Hi John Measured mine today and from the top of that panel to that edge where the valance starts to curve under is 55mm. Mine has been replaced so im not sure how accurate this is to factory setup. But mine is that same height across that middle section. Hope this helps a bit. Andy Quote Link to comment Share on other sites More sharing options...
john hibbert Posted May 30, 2023 Author Share Posted May 30, 2023 like that sketch i did above bottom of the grill panel to the start of the valance cure of valance 55mm ?thanks Quote Link to comment Share on other sites More sharing options...
611 Posted May 30, 2023 Share Posted May 30, 2023 4 hours ago, john hibbert said: like that sketch i did above bottom of the grill panel to the start of the valance cure of valance 55mm ?thanks Yep, from the flat of that panel just under the grill to the curve of the valance panel and if you did it from the flat of that panel to the bottom of that panel where it stops and the valance tucks under it was approx 40mm From your pic with the tape measure you don't seem to be far off? I think the main issue you can have if the panel is too far up or down is lining up the wing fixings and join at the edge of the valance. Can you test fit a wing as well to double check before you weld up? Quote Link to comment Share on other sites More sharing options...
john hibbert Posted May 31, 2023 Author Share Posted May 31, 2023 yep your right on the test fit wings done, thanks for measurement big help 👍 Quote Link to comment Share on other sites More sharing options...
611 Posted June 1, 2023 Share Posted June 1, 2023 23 hours ago, john hibbert said: yep your right on the test fit wings done, thanks for measurement big help 👍 No problem. Happy to help. I have been through the same as you to get mine on the road so if you need any other help just let me know as i think i have replace every part you can on the A 🙂 Andy Quote Link to comment Share on other sites More sharing options...
john hibbert Posted June 1, 2023 Author Share Posted June 1, 2023 Top MAN 👍 Will start posting some photos in the next few weeks when i start sticking her back together 👍 Quote Link to comment Share on other sites More sharing options...
