Speedo Cable Route
Jonathan Pounsett
from what i remember it comes up through the centre hole and then down very near the clutch or brake wear switch before dissapearing behind the heater box then out through the grommet. i think it should be self explanatory if you just feed it across from the passenger side and temporarily sit the instruments in place .
  • Thanks 1
Your dashboard makes me feel better, not just mine in a state of spaghetti. So on my Cav Sportshatch, the speedo cable enters the bulkhead at a point to the left of the tunnel in the passenger footwell. It then goes to the rear of the heater box up to the back of the speedo. Maybe different if your car uses the 5 speed ‘box.
  • Thanks 1
