1200bandit Posted August 14 Share Posted August 14 Need the lower alloy boss , top spring , washers for the steering column Had play in the steering wheel,removed the the wheel with the boss,found the 22mm nut very loose ( removed by hand ) Alloy boss cut to bits, Could do with asap as can’t move the manta without it The second photo is of the spring required ( it was missed when removed) Link to comment Share on other sites More sharing options...
