retrocarclub Posted March 18, 2009 Share Posted March 18, 2009 Hi, i'm considering investing in a Quaife ATB Differential for my mk1 Cavalier saloon. However, the Quaife website doesn't list a diff. for a mk1 Cavalier so would I be ok getting a Manta diff. or should I get an Ascona diff? Cheers Christian Quote Link to comment Share on other sites More sharing options...
rutts Posted March 19, 2009 Share Posted March 19, 2009 Hi, i'm considering investing in a Quaife ATB Differential for my mk1 Cavalier saloon. However, the Quaife website doesn't list a diff. for a mk1 Cavalier so would I be ok getting a Manta diff. or should I get an Ascona diff? Cheers Christian which axle do you have, 1.3 - 1.6/1.9. if its the 1.6/1.9 then order the manta diff, you need to also find a good gearbox/axle reconditioners to fit the diff as the diff needs shimming up to get the crown wheel to pinion gear aligned correctly or it could go ar*e up. Quote Link to comment Share on other sites More sharing options...
retrocarclub Posted March 19, 2009 Author Share Posted March 19, 2009 which axle do you have, 1.3 - 1.6/1.9. if its the 1.6/1.9 then order the manta diff, you need to also find a good gearbox/axle reconditioners to fit the diff as the diff needs shimming up to get the crown wheel to pinion gear aligned correctly or it could go ar*e up. Neither of those, mines a 2.0 Oh really I thought they were supposed to be a straight swap? Quote Link to comment Share on other sites More sharing options...
16VManta Posted March 19, 2009 Share Posted March 19, 2009 It's the medium axle, so yes it's the one. The only difference between the diffs is whether you want one for a 3.44:1 or a 3.67:1. Quote Link to comment Share on other sites More sharing options...
retrocarclub Posted March 20, 2009 Author Share Posted March 20, 2009 Ok cheers. Has anyone ever fitted one on here? Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted March 20, 2009 Share Posted March 20, 2009 Fitted these is a professional job......plus cost is dependant on how good your diff bearings are, these are expensive to buy Quote Link to comment Share on other sites More sharing options...
retrocarclub Posted March 20, 2009 Author Share Posted March 20, 2009 Fitted these is a professional job......plus cost is dependant on how good your diff bearings are, these are expensive to buy Ah that's a bugger. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted March 22, 2009 Share Posted March 22, 2009 Re Diff Bearings see:- http://forums.mantaclub.org/index.php?showtopic=21530 Quote Link to comment Share on other sites More sharing options...
