bhp Posted March 28, 2009 Share Posted March 28, 2009 Has anyone out there got some pictures of their answer to the above problem? Hope to hear from you all soon, bhp............ Quote Link to comment Share on other sites More sharing options...
bhp Posted April 2, 2009 Author Share Posted April 2, 2009 Has nobody come accross the problem of the Anti-Roll bar & the exhaust downpipes when fitting the XE engine into the A series????? Quote Link to comment Share on other sites More sharing options...
manta88 Posted April 2, 2009 Share Posted April 2, 2009 I think you have to do something like Paul did on his V8 by dropping the anti roll bar out of the way of the exhaust. Quote Link to comment Share on other sites More sharing options...
simon p Posted April 2, 2009 Share Posted April 2, 2009 The only way around your problems are to fabricate what you need, there is no off the shelf manifold for the A. I make all mine to suit each job. As for the anti rollbar problem, the picture above is one option, another option is the modify the mounting points, however, if you play around you may be able to fit the anti rollbar without modding anything. Quote Link to comment Share on other sites More sharing options...
upk Posted April 2, 2009 Share Posted April 2, 2009 The only way around your problems are to fabricate what you need, there is no off the shelf manifold for the A. I make all mine to suit each job. As for the anti rollbar problem, the picture above is one option, another option is the modify the mounting points, however, if you play around you may be able to fit the anti rollbar without modding anything. worked for me and no obvious drawbacks with handling.................my local machine shop made these to my drawing which i can send you if you let me have your email. http://forums.mantaclub.org/index.php?show...=8182&st=40 Quote Link to comment Share on other sites More sharing options...
