paulmcclung Posted April 10, 2009 Share Posted April 10, 2009 Hi all. I need to do the fuel lines on my GTE. What pipe would you all recomend using. Quote Link to comment Share on other sites More sharing options...
manta400john Posted April 10, 2009 Share Posted April 10, 2009 Plastic stuff from any VW,Fiat,Vauxhall. Get it at yer local srappy for next to nothin'. It's a doddle to use..better than the copper stuff. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted April 10, 2009 Share Posted April 10, 2009 Some of the copper stuff similar to brake pipe (or actually brake pipe). Check diameter, I think it's about 7mm but check. My copper stuff has been on for 10 years now, lasted longer than the original. For the fuel rails and flexible pipes pay the premium for the Vauxhall dealer stuff, I have found that it also lasts many times longer then the injection rated pipe I have had from factors. Once assembled use the 2p trick to run the pump and flush the lines back into the tank just to be sure you don't get any dust or dirt in the injectors. Quote Link to comment Share on other sites More sharing options...
midasmesh Posted April 11, 2009 Share Posted April 11, 2009 Got some of the plastic coated copper pipe on mine. Should last a fair while. Quote Link to comment Share on other sites More sharing options...
