RoryRN Posted April 12, 2009 Share Posted April 12, 2009 Hi, I have bought a manta A with an XE in it but theres a few things im not happy with and wondered if someone on here would be able to help me; Firstly what engine mounts should be fitted as my current ones are manta b with a 10mm plate underneath to raise the engine but it knocks off the steering rack at full tilt, What radiator would you recommend to use its got a standard manta a rad at the mo but she can get a little hot Also there seams to be a weep of oil in my water but no water in my oil and i cant work out what it can be anyone got any ideas? Thanks in advance Rory Quote Link to comment Share on other sites More sharing options...
MANTA ROB 69 Posted April 12, 2009 Share Posted April 12, 2009 Hi Rory Not sure about the A but im running the 50mm Capri mk3 mounts on my B with the XE but i think they are like hen's teeth now. Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 12, 2009 Share Posted April 12, 2009 Hi Rory Not sure about the A but im running the 50mm Capri mk3 mounts on my B with the XE but i think they are like hen's teeth now. You can buy these engine mounts from any decent motor factor, ralley design, various ford based outlets, ebay etc etc Quote Link to comment Share on other sites More sharing options...
Robbie Posted April 12, 2009 Share Posted April 12, 2009 i have a set of new mounts here Rory could rop them of with your clocks if you want sent you a pm, A manta B GTE radiator will work perfectly with the XE and fits straight in, maybe your A series rad is a 1600 one or if its a 1900 may have slightly blocked waterways. Your head gasket may be on the way out with the oil in the water, that wont help your heating problems either Quote Link to comment Share on other sites More sharing options...
