Help Gte Wont Rev And Pops Through Airbox
battz02
Check you haven't got any leaks in the pipe from airbox to plenum. They can split and cause what you desgribe. Also check the inlet/exhaust manifolds haven't worked loose and that the gaskets ok. Throttle body could also need cleaning out. I'm assuming the plugs etc are ok.
plugs etc are ok and have checked the air pipes but without any joy
please ensure you have eliminated the problem
( bad earth , sitting on exhaust, etc )
or your new loom might do the same .............. ;)
it was sitting on the exhaust so will sort that out onl;y had the car 2 weeks so hadnt had chance to even look at it yet
