2.0S Mk1 Cav Reading Hot
retrovauxhall
HELP????? :unsure:
Ok heres my problem, my car is reading hot as in in the red when its not, ive tried many different sender units and its the same yet when i take the thermostat out it reads accurate, ive not lost any water the car isnt overheating can anyone advise on this? the car was originaly a 1600 and i put the 2.0 engine into it>
I thought that initially Gary ... but the running at normal with the stat out makes me wonder Hhhmmmmm :unsure:
Maybe its a higher rated thermostate .. and not opening at 87 C'...
" Just a little tip "
Whenever fitting a new thermostate I always drill a hole in the flange . This allows a small flow of warmed water around the wax filled valve and assists in opening and helps to guard against air-locks in the cooling system ...
Hope this helps ...
If your a member of the cav club? Wouldn't they be able to help you out?
im in the mk1 cav club but theres no active forum, but im a member of this club and always find it has much more benefits
regards
Hope this helps ...
i already drilled a whole but is it possible could still be thermostat, its just its reading hot but we put a scanner on the block and its not running hot, think it was between 80 and 90 degrees
