jasonpirtek Posted October 4, 2009 Share Posted October 4, 2009 pondering brake set ups i am building a redtop with rear disc set up etc has anyone fitted a bulkead mounted balance box whilst running bike carbs? i am not sure whether the box will fit? cheers Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 4, 2009 Share Posted October 4, 2009 Do you mean one of those universal brake bias boxes that bolts into the engine bay in place of the servo? If so i don't think there is clearance. When i made my bias pedalbox i looked at making a copy of one of those boxes and there wasn't room for it and my bikecarb setup So i made mine much more compact and have the cylinders about 1 inch infront of the bulkhead. It did mean modifying the brake pedal to add the bias adjuster and enlarging the hole in the bulkhead to give clearance for the 2 rods of the cylinders. But it gives loads of room for the bikecarbs Quote Link to comment Share on other sites More sharing options...
jasonpirtek Posted October 4, 2009 Author Share Posted October 4, 2009 hi yes its the universal one, i saw it at rallydesign just looks like the cage for it might be a bit to big. i was just looking for the lazy of the self option! could you send a pic of yours if it is at all possible? cheers Quote Link to comment Share on other sites More sharing options...
Robbie Posted October 4, 2009 Share Posted October 4, 2009 (edited) Bike carbs sit at a higher angle than 45's etc which allows them to be fitted with a standard servo, so fitting a coupe of master cylinders is no problem. Not sure on the bias box you are thinking of but with bike carbs on a blogg bros manifold there is loads of room. Get a proper manta bias box and you will have no problem mail TJM on here or vxopel.com Tim knows the Vxopels inside out and will sort you with a pedal box like this http://www.tjmotorsport.co.uk/proddetail.php?prod=PB02 Edited October 4, 2009 by Robbie Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 4, 2009 Share Posted October 4, 2009 The universal bias boxes look like this, and take up a load of room in the engine bay I'll get a picture of mine tomorrow if i remember Quote Link to comment Share on other sites More sharing options...
Robbie Posted October 4, 2009 Share Posted October 4, 2009 The universal bias boxes look like this, and take up a load of room in the engine bay I'll get a picture of mine tomorrow if i remember Thats big David, its the height that hammers the normal servo needing a slice out of the servo with 40's etc or the bike carbs clear. That brake bias servo looks like it takes a ball of room as well, I'd give it a miss and go for the proper one I posted the link to before on TJM's site. How much is the universal onw by the way. Quote Link to comment Share on other sites More sharing options...
jasonpirtek Posted October 5, 2009 Author Share Posted October 5, 2009 Thats big David, its the height that hammers the normal servo needing a slice out of the servo with 40's etc or the bike carbs clear. That brake bias servo looks like it takes a ball of room as well, I'd give it a miss and go for the proper one I posted the link to before on TJM's site. How much is the universal onw by the way. it is the box rally design sell think its £130 seamed an easy option,but it does look quite big so need to make sure i will try tjm also. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 5, 2009 Share Posted October 5, 2009 Ok found a pic of my pedalbox that i took when fitting it, well the engine bay side of it at least. Its a very basic thing really, its about a 30mm thick box which i made up, On the front it has studs coming out either side of 2 large holes, which the master cylinders bolt to the rear has 4 studs in the same pattern as the back of the standard servo, so it bolts to the bulkhead where the original hole in the bulkhead was i extended it sideways both ways for clearance for the rods The brake pedal had the bias bar tube welded to it just above where the standard rod attaches i did have to trim away the side of the original pedalbox slightly to clear the assembly on the pedal but i added an extra bar back in to replace the strength I had a slightly easier time than i was expecting as i borrowed my mates manta bulkhead piece he cut out of an old scrap car Its just the area that the pedalbox attaches to, but meant i could look at it and try things without lying upside down in the footwell I did it this way for several reasons, 1: The universal boxes take up too much room 2: I didn't want the cylinders or resevoirs in the car (its a rally car and service-ability if something goes wrong is very useful) 3: Down the line i'm planning on fitting electric power steering and want to keep the space under the dash empty Oh and i'm tight and prefer making things than buying them Quote Link to comment Share on other sites More sharing options...
jasonpirtek Posted October 6, 2009 Author Share Posted October 6, 2009 Ok found a pic of my pedalbox that i took when fitting it, well the engine bay side of it at least. Its a very basic thing really, its about a 30mm thick box which i made up, On the front it has studs coming out either side of 2 large holes, which the master cylinders bolt to the rear has 4 studs in the same pattern as the back of the standard servo, so it bolts to the bulkhead where the original hole in the bulkhead was i extended it sideways both ways for clearance for the rods The brake pedal had the bias bar tube welded to it just above where the standard rod attaches i did have to trim away the side of the original pedalbox slightly to clear the assembly on the pedal but i added an extra bar back in to replace the strength I had a slightly easier time than i was expecting as i borrowed my mates manta bulkhead piece he cut out of an old scrap car Its just the area that the pedalbox attaches to, but meant i could look at it and try things without lying upside down in the footwell I did it this way for several reasons, 1: The universal boxes take up too much room 2: I didn't want the cylinders or resevoirs in the car (its a rally car and service-ability if something goes wrong is very useful) 3: Down the line i'm planning on fitting electric power steering and want to keep the space under the dash empty Oh and i'm tight and prefer making things than buying them thanks for pic it gives me some ideas, i been building well trying for two years, i don't think the universal box will work. might need to pick your brains again. cheers jason. Quote Link to comment Share on other sites More sharing options...
