GTEPETE Posted February 8, 2010 Share Posted February 8, 2010 Still investigating if I can use slightly shortened Commodore rear shafts in my GTE lsd axle which I have not yet stripped. If someone has a GTE shaft out of its axle can they measure the length from the front flange face of the shaft to the end of the splined end in mm. Guess you may have to measure on an angle...thanks Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted February 8, 2010 Share Posted February 8, 2010 Still investigating if I can use slightly shortened Commodore rear shafts in my GTE lsd axle which I have not yet stripped. If someone has a GTE shaft out of its axle can they measure the length from the front flange face of the shaft to the end of the splined end in mm. Guess you may have to measure on an angle...thanks Just stripped out 5 axles so inundated with half shafts!!!! Front face being the face that the drum sits up to? I'll have a look tonight Cheers Chris Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted February 8, 2010 Author Share Posted February 8, 2010 Thanks Chris, and yes measure from the drum side...ps can you measure square to the shaft as the flange on the Commodore shaft is a larger diameter than a GTE one so measuring on the slope will not be accurate... Quote Link to comment Share on other sites More sharing options...
mantadoc Posted February 8, 2010 Share Posted February 8, 2010 Seem to remember making it 10 mm by eye but that might have been bearing to bearing, but as long as the end doesn't intrude far enough to foul the planet gears or axis does it matter? Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted February 8, 2010 Author Share Posted February 8, 2010 Thanks Mantadoc, people have said that you end up with just 10mm of spline left after shortening, which will not be any use. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted February 8, 2010 Share Posted February 8, 2010 Just been out and measured a spare shaft and i get 711mm from outside of flange keeping paralel to the shaft. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted February 9, 2010 Author Share Posted February 9, 2010 thanks, mantasrme. Just one more thing, what is the length of the splines? Quote Link to comment Share on other sites More sharing options...
mantasrme Posted February 9, 2010 Share Posted February 9, 2010 Total length of splines is 39mm On my used shafts looking at the wear marks the first 9mm wasn't in anything So 29mm into the splines of the gear in the diff standard. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted February 9, 2010 Author Share Posted February 9, 2010 Total length of splines is 39mm On my used shafts looking at the wear marks the first 9mm wasn't in anything So 29mm into the splines of the gear in the diff standard. thanks mate, will check my shafts later... Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted February 9, 2010 Author Share Posted February 9, 2010 mantasrme, one set of shafts I have has already been shortened to 720 (not by me)..Trying to work out exacttly what length of spline engages in the diff.You mentioned the first 9mm was unworn so left about 29mm spline, by looking at the wear marks on your shafts do you think all of the 29mm engages in the diff or a shorter amount? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted February 9, 2010 Share Posted February 9, 2010 I'd still measure from the bearing seat as the drum setup may have been wider so length from the mounting face could give false info Quote Link to comment Share on other sites More sharing options...
mantasrme Posted February 10, 2010 Share Posted February 10, 2010 The end 29mm all looks the same, so i would guess its all in the gear. I've also checked the measurment from inner face of bearing to end of shaft which is 633mm Just in case as Mantadoc says there is a difference in the outer end of the shaft. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted February 10, 2010 Author Share Posted February 10, 2010 The end 29mm all looks the same, so i would guess its all in the gear. I've also checked the measurment from inner face of bearing to end of shaft which is 633mm Just in case as Mantadoc says there is a difference in the outer end of the shaft. Thanks for all your help...once I get round to fitting shafts I will post up details and pictures. Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted February 16, 2010 Share Posted February 16, 2010 Thanks for all your help...once I get round to fitting shafts I will post up details and pictures. Pete Sorry it's taken so long to get back to you, had a few probs. Shaft length is 711mm as stated by mantasrme. The splines i've measured are 42 mm of full engagement length (not including the cutter run out). The wear marks on 2 sets of the shafts are 31mm long BUT there is a set that has a 36 mm wear mark length. I've checked with a dif that i have out of the casing and the spline on the planet gear is approx 31mm. It could be that the 31mm wear marks are from a 3.44 carrier and the longer wear marks are from the dead 3.67 carrier. The shaft ends with about 1mm protruding into the diff. HTH Chris Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted February 17, 2010 Author Share Posted February 17, 2010 Thanks Chris for taking the trouble to check for me, very useful..... Pete Quote Link to comment Share on other sites More sharing options...
