costasa Posted February 26, 2010 Share Posted February 26, 2010 (edited) Hi, here am i putting another question. I spot in german ebay http://cgi.ebay.de/O...=item3efc665c21 Buchse für Ausleger vorne (Opel-Ersatzteil-Nr. 3 50 150/153) "Opel Manta/Ascona A/B" NEUTEIL !!! TOP-QUALITÄT!!!! If this are correct the manta B bushes front anti-roll bar work in Manta A ?? Thanks Costa Edited February 26, 2010 by costasa Quote Link to comment Share on other sites More sharing options...
Shug Posted February 26, 2010 Share Posted February 26, 2010 (edited) That looks like the bush that goes in the arm that bolts to the chassis. (very top of picture) The anti roll bar bushes are different on the A and B. Edited February 26, 2010 by Shug Quote Link to comment Share on other sites More sharing options...
costasa Posted February 26, 2010 Author Share Posted February 26, 2010 (edited) That looks like the bush that goes in the arm that bolts to the chassis. (very top of picture) The anti roll bar bushes are different on the A and B. Thanks Shug, i try to translate the german to portuguese and english and i was with doughts. That bushes that bolt in the chassis i have to drill and destroy to take off the arms, so i don't have the ideia how they look, and the bushes from the front anti-roll bar where very used and damaged so i dont know how they look too. Edited February 26, 2010 by costasa Quote Link to comment Share on other sites More sharing options...
costasa Posted February 26, 2010 Author Share Posted February 26, 2010 After some hours searching for a picture of the front anti-roll bar bushes i find this At least i know now how looks the bushes. Quote Link to comment Share on other sites More sharing options...
mantaray Posted February 26, 2010 Share Posted February 26, 2010 This may be of help to you. Quote Link to comment Share on other sites More sharing options...
costasa Posted February 26, 2010 Author Share Posted February 26, 2010 This may be of help to you. Thanks mantaray, thanks very much the drawings will help a lot Quote Link to comment Share on other sites More sharing options...
TJM Posted February 27, 2010 Share Posted February 27, 2010 Hi After a bit of research I have found the following: Manta Part No: 3451279 (Same as Manta B/Kadett C) Superflex SPF1552 90023989 (Same as Manta B/Kadett C) Superflex SPF1553 2888701 (Same as Manta B/Kadett C) Superflex SPF0402 8952179 (Same as Manta B/Kadett C) Superflex SPF0403 6661989 (Same as Manta B/Kadett C) Superflex SPF1812/Check anti roll bar diameter. 6655341 (Same as Manta B/Kadett C) Superflex SPF0513 2893381 (Same as Manta B/Kadett C) Superflex SPF0030 2892968 (Same as Manta B/Kadett C) Superflex SPF0030T I will see iof I can match all the other numbers. Regards Tim Quote Link to comment Share on other sites More sharing options...
costasa Posted March 1, 2010 Author Share Posted March 1, 2010 Hi After a bit of research I have found the following: Manta Part No: 3451279 (Same as Manta B/Kadett C) Superflex SPF1552 90023989 (Same as Manta B/Kadett C) Superflex SPF1553 2888701 (Same as Manta B/Kadett C) Superflex SPF0402 8952179 (Same as Manta B/Kadett C) Superflex SPF0403 6661989 (Same as Manta B/Kadett C) Superflex SPF1812/Check anti roll bar diameter. 6655341 (Same as Manta B/Kadett C) Superflex SPF0513 2893381 (Same as Manta B/Kadett C) Superflex SPF0030 2892968 (Same as Manta B/Kadett C) Superflex SPF0030T I will see iof I can match all the other numbers. Regards Tim Thanks Tim your research helps now i can cross reference and see what bushes i can use in my Manta A I think that this information will help others Quote Link to comment Share on other sites More sharing options...
