Jason b Posted March 9, 2010 Share Posted March 9, 2010 Hi, I expect I can already guess the answer, however searches of various forums has left me fruitless... will the LSD from a mk2 carlton GSI3000 fit in a mk1 cavalier axle? as an aside, I take it that the 5spd box from a carlton can be fitted to the cav with a mod to the transmission tunnel? Many thanks! Jason Quote Link to comment Share on other sites More sharing options...
rutts Posted March 10, 2010 Share Posted March 10, 2010 no the lsd does not fit unless you strip it down and get it machined to the manta/cavalier axle dimentions, if it was easy i think we would all be doing it. i was told with the amount needed to be taken off the diff to fit the diff would be a very weak point. buy a gripper diff it fits and does the job. gearbox will fit engine but you need to half prop shafts welding and balancing to fit it. Quote Link to comment Share on other sites More sharing options...
Jason b Posted March 10, 2010 Author Share Posted March 10, 2010 no probs, thats why i said I probably already knew the answer - if something is easy then it is already done many times. I got offered one and thought it would be worth checking. Cheers Jason Quote Link to comment Share on other sites More sharing options...
