deanosabby Posted April 6, 2010 Share Posted April 6, 2010 Hi guys, As above I am needing a master cylinder for my MK1 cavvy coupe as my one is leaking internally so if you have a good one new or used then give me a shout. I have been told anyone from a manta/cav range will do. Ta, Deano. Link to comment Share on other sites More sharing options...
Shug Posted April 6, 2010 Share Posted April 6, 2010 You can get rebuild kits from bigg red on ebay for about 15 - 20 quid if yer keen. Link to comment Share on other sites More sharing options...
deanosabby Posted April 6, 2010 Author Share Posted April 6, 2010 Cheers shug I will have a look I have bought one on ebay just now but it says it is for a 1.6 from 1975/80 but it looks like the right part with all the bolts and brake pipe connections in the right place. Once it arrives Bill Dalgety will be able to double check it to see if it will do the job. Ta, Deano. Link to comment Share on other sites More sharing options...
Julian Posted April 6, 2010 Share Posted April 6, 2010 (edited) Cheers shug I will have a look I have bought one on ebay just now but it says it is for a 1.6 from 1975/80 but it looks like the right part with all the bolts and brake pipe connections in the right place. Once it arrives Bill Dalgety will be able to double check it to see if it will do the job. Ta, Deano. I'm not absolutely sure but the inside bore diameter may be smaller on the 1.6 application. Edited April 6, 2010 by Julian Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted April 11, 2010 Share Posted April 11, 2010 Is it 19 or 20mm? Is it Delco or Ate? Link to comment Share on other sites More sharing options...
