Manta A Poly Bushes
bjm
Hi, the manta B rear bushes are the same as the A
In the front only the lower arm looks to be diferent, i buy from TJM (great seller) the bushes and in a post about poly bushes you can check the references (just make a search that you will find the topic)
In this link
http://s848.photobucket.com/albums/ab49/costasa/Poly%20Bushes/
You can see the front bushes that i buy from TJM to my front axel, all looks to fit ok ( i'm not tried in the car because i'm to blast and paint the front and rear axel)
You can buy front poly bushes in Dr.Manta and from Lenk Tuning
Good luck
