74009 Posted October 29, 2010 Share Posted October 29, 2010 (edited) Hi all, I need a new Water Pump for my 1986 GT/E; seems there are two types, Solid or Viscous fan. How do I tell which kind I want (or will either work)? Cheers Stuart Edited October 29, 2010 by 74009 Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted October 29, 2010 Share Posted October 29, 2010 It'll be a vicious type for an 86 GTE Quote Link to comment Share on other sites More sharing options...
mantaray Posted October 29, 2010 Share Posted October 29, 2010 How do you tell the differance ? I have one for sale, but not sure which one it is. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted October 29, 2010 Share Posted October 29, 2010 Pump for fixed fan had a flat face with four bolt holes in. Pump for visco had the pulley, usually with a cone shape and a large threaded secsion sticking out of the middle. The one ambiguity is some pumps, usually seen on older 6 cylinder motors used the standard pump with four bolt holes bur a different visco coupleing that bolted to this essentially standard pump. All the bolts used to secure pulley and fixed fan or pulley and the wierd visco had 10mm heads. Basically if there are 4 bolt heads holrding the pulley and / or fan on it is one type, and if no bolt heads visible the other. Quote Link to comment Share on other sites More sharing options...
74009 Posted October 31, 2010 Author Share Posted October 31, 2010 Thanks all for your answers... Best regards Stuart Quote Link to comment Share on other sites More sharing options...
