mantapaperman Posted November 1, 2010 Share Posted November 1, 2010 (edited) hi all. just going to start the task of changing me brake pipes for the mot. can anyone advise what size of copper pipe i need. will it be 3/16 ? also anyone know what thread the unions are? many thanks in advance..ooh and are these cheap FLEABAY FLARING TOOLS ANY GOOD can anyone recomend a good flarer brand..cheers Edited January 10, 2011 by mantapaperman Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 1, 2010 Share Posted November 1, 2010 Yes they're 3/16 pipes, think they're M10x1mm unions As for the cheap pipe flarer's they can be made to make a reasonable flare in the pipe but from my experience only once in 20 times If you're only going to do a couple of pipes i'd say get a local garage to flare the ends for you once you've cut them to length Or if you want to add a decent flaring tool to your tool box you want a vice mounted one like this E-Bay link which are £160ish new Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted November 1, 2010 Author Share Posted November 1, 2010 thanks very much for the info..think yur right about getting someone to flare them. as once these are done i wont be flaring any more for a while..thanks again Quote Link to comment Share on other sites More sharing options...
mantadoc Posted November 1, 2010 Share Posted November 1, 2010 As for the cheap pipe flarer's they can be made to make a reasonable flare in the pipe but from my experience only once in 20 times Brothers Blue Point "on the car" one is about 32 years old and my Clarke "on the car" one is about 15 years old and was about £22 quid from MachineMart. Something like 16 ends on a Manta, and how many times are you going to do a whole car? On one hand good tools make better ends, how much is your safety worth? On another cost/benefit. If a garage did your brakes which would they use? Would you even ask? Quote Link to comment Share on other sites More sharing options...
