matt24680 Posted December 12, 2010 Share Posted December 12, 2010 hi guys i have a 1984 gte hatch and was wandering does any1 have any pics of theres lowered?and by how much? also if i was to use lowering springs with standard shocks would the ride be pretty awfull? thanks Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted December 12, 2010 Share Posted December 12, 2010 Got a pic of my old Cav Sportshatch lowered on 13" ATS Classics if that's any good to you? It was ridiculously low mind you... Quote Link to comment Share on other sites More sharing options...
markben Posted December 12, 2010 Share Posted December 12, 2010 my coupe had jamex sportsline dampers and springs all round .was a hard ride but stuck like glue .http://s1132.photobucket.com/albums/m570/markben2010/?action=view¤t=scan0006.jpg will see if i have hatch pics for you . Quote Link to comment Share on other sites More sharing options...
2908642343 Posted December 12, 2010 Share Posted December 12, 2010 (edited) Pictures from earlier this year. Spax PSX -40 on 195 55 15 ATS. Edited December 12, 2010 by 2908642343 Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted December 12, 2010 Share Posted December 12, 2010 My hatch was lowered 60mm on some cheap springs from online autosport. I ran it with standard shocks which worked fine till 1 started leaking so put in a set of bilsteins. Cheers, Peter. Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted December 13, 2010 Share Posted December 13, 2010 My hatch was lowered 60mm on some cheap springs from online autosport. I ran it with standard shocks which worked fine till 1 started leaking so put in a set of bilsteins. Cheers, Peter. My coupe sits about another 15mm lower than these pics (can tell by where the tops of the tyres are) The springs fitted were jamex -60mm. The shocks are bilstein adj up front and kyb gas on the rear. I had problems with the suspension getting to the point of hitting the bump stops. Cure was take 40mm off the bump stop and refit in position. Checked the travel of the suspension and everything was ok. I did actually turn the top ball joints to give more positive camber as the 60mm drop gave a little too much negative camber, just the way the wishbone suspension works. That cured the slight scrub i was getting on the front tyres (about 2.5mm across the tread) HTH Chris Quote Link to comment Share on other sites More sharing options...
