yorkshirelad Posted January 20, 2011 Share Posted January 20, 2011 Does anyone know where I can get a new master brake cylinder for a 76 B coupe with 1.9 engine? I've tried the usual, ebay, German ebay, Brakes Int. Etc. Or is there a straight fit alternative from a different make of vehicle? Mine is ATE brand. Thanks. Link to comment Share on other sites More sharing options...
madmantamik Posted January 20, 2011 Share Posted January 20, 2011 these are still available but very costly try here www.brakeparts.co.uk or brakesinternational.co.uk, good luck .is it not a better idea to locate a good secondhand one and a seal kit. Link to comment Share on other sites More sharing options...
gary6303 Posted January 20, 2011 Share Posted January 20, 2011 bmw e30 one fit onto the manta servo infact the whole servo,cylinder fits onto the manta baulkhead, could go to a scrapyard and fit that, mines from a 318i. Link to comment Share on other sites More sharing options...
monkeynuts Posted January 21, 2011 Share Posted January 21, 2011 Does anyone know where I can get a new master brake cylinder for a 76 B coupe with 1.9 engine? I've tried the usual, ebay, German ebay, Brakes Int. Etc. Or is there a straight fit alternative from a different make of vehicle? Mine is ATE brand. Thanks. as usual i have a used one in working condition! cover the postage and you can have it also here is a link to a repair kit for ate cylinders. if you haven't done one before they're quite easy to do. http://cgi.ebay.co.uk/Opel-Ascona-Manta-Brake-Master-Cylinder-repair-kit-1124-/310289448333?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483eb13d8d hopes this helps jason Link to comment Share on other sites More sharing options...
cam.in.head Posted January 22, 2011 Share Posted January 22, 2011 hi mate. thers one popped up on ebay right now. doesnt say wether its ate or delco so you would need to get the seller to measure the mounting bolt hole spacing or check for any info on the box. cant quite see from the picture. cheers. listed as brake master cylinder cavalier mk1 Link to comment Share on other sites More sharing options...
