rust4life Posted March 3, 2011 Share Posted March 3, 2011 (edited) Hi All, I'm after a Manta auto propshaft Near Oxford would be helpful. Am currently breaking a GT/J hatch here :- http://forums.mantac...ing-for-spares/ so cd do swap/px for other parts cheers, Ben Edited March 25, 2011 by rust4life Link to comment Share on other sites More sharing options...
manscoob Posted March 5, 2011 Share Posted March 5, 2011 i have a drive shaft, still on the car!!! let me know if you still need one??? cheers john Link to comment Share on other sites More sharing options...
rust4life Posted March 25, 2011 Author Share Posted March 25, 2011 John's one was duff so still looking - anyone got one?? Link to comment Share on other sites More sharing options...
upk Posted March 26, 2011 Share Posted March 26, 2011 Why not get a std prop and have it shortened?? i did when i did the conversion in my A series. kev Link to comment Share on other sites More sharing options...
bilsport Posted March 27, 2011 Share Posted March 27, 2011 Hi, I've got a manta a automatic prop here.It measures 598mm between the centres of the uj's. The splined end fits the gte getrag box. The uj's seem to be in good condition. There is some surface rusting but it is only cosmetic. regards, Will Link to comment Share on other sites More sharing options...
rust4life Posted March 28, 2011 Author Share Posted March 28, 2011 you have been pm'd Link to comment Share on other sites More sharing options...
mantadoc Posted March 28, 2011 Share Posted March 28, 2011 Doesn't the chevette prop bolt onto the axle on a flat surface with four bolts into the threaded axle flange, whereas the Mantas have the bearing knuckle exposed and is not flat, won't fit and is held on by two U bolts? Link to comment Share on other sites More sharing options...
rust4life Posted March 28, 2011 Author Share Posted March 28, 2011 Am hoping to use the Manta back axle aswell so shd fit together ok? Have been told that the auto prop will fit between the manta gearbox and axle when put in a chevette as it is shorter than standard manta manual prop. Link to comment Share on other sites More sharing options...
mantadoc Posted March 28, 2011 Share Posted March 28, 2011 Am hoping to use the Manta back axle aswell so shd fit together ok? Have been told that the auto prop will fit between the manta gearbox and axle when put in a chevette as it is shorter than standard manta manual prop. Hear that about the Manta A too I think. If time is an issue might be as well go go to reco-prop or someone like that for a shortening and have new UJs at same time Link to comment Share on other sites More sharing options...
rust4life Posted March 28, 2011 Author Share Posted March 28, 2011 Yes, may well do that - haven't yet had time to start fitting the engine, 'box and back axle yet so was jst thinking that it would be handy to have a complete 'kit of parts' ready for when it all starts to go together in the next few weeks but not too time critical as it can be one of the last bits fitted . Link to comment Share on other sites More sharing options...
