discodas Posted March 16, 2011 Share Posted March 16, 2011 Morning chaps, Does any one have or know wheres I can source Timing / Cam belt 1.8 1983 manta (111 teeth) and (45 teeth), also need new water pump gasket O ring thing. Looking for GM OE if at all possible, has any one used the obsolete opel parts in birmingham?? Poss might need the other belt thing that go to Dizzy? Thanks in advance Darryl Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted March 16, 2011 Share Posted March 16, 2011 Morning chaps, Does any one have or know wheres I can source Timing / Cam belt 1.8 1983 manta (111 teeth) and (45 teeth), also need new water pump gasket O ring thing. Looking for GM OE if at all possible, has any one used the obsolete opel parts in birmingham?? Poss might need the other belt thing that go to Dizzy? Thanks in advance Darryl If you will not find....i can help Link to comment Share on other sites More sharing options...
andyc Posted March 16, 2011 Share Posted March 16, 2011 Gm Timing Belt £16.62 (OMOC Memeber Cost £12.11) Gm Water Pump £50.77 (OMOC member Cost £43.15) Gm Water Pump Seal £2.69 (OMOC Member Cost £2.30) Gm Water Pump Bolts, 3@£1.09 eac (OMOC Member Cost £0.95 each) Gm Dissy belt £6.40 (OMOC Member Cost £5.44) Pump and Dissy Belt only avaliable from Opel All prices subject to VAT @ 20% Cheers Andy Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted March 16, 2011 Share Posted March 16, 2011 Timing Belt Gates (OEM) 17 Euros and Genuine 35 Euros Water Pump 30 Euros economy 45 Euros Italy or 60 Euros in genuine(the genuine has 121 Euros retail price!) Pump Seal 0,30 Euros Distributor belt Gates (OEM) 6 Euros Genuine 11 Euros All of the above prices are dealer NET prices so the same discount to forum members Air mail post till 1kg is 26 Euros Air mail post till 2kg is 31 Euros Air mail post till 4kg is 34 Euros Paypal fee is +4.4% O.P.G. Link to comment Share on other sites More sharing options...
rutts Posted March 16, 2011 Share Posted March 16, 2011 get new seal from vauxhall and buy gates belts from normal car accessory shop. gates belts are what vauxhall and others use as original fitting . Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted March 16, 2011 Share Posted March 16, 2011 get new seal from vauxhall and buy gates belts from normal car accessory shop. gates belts are what vauxhall and others use as original fitting . +1 the Gates are considered OEM many years now And the seal no need to find/buy it in genuine since you will find easily the 3mm X 89.5mm O ring to any O-rings/gaskets shop!!!! Link to comment Share on other sites More sharing options...
discodas Posted March 16, 2011 Author Share Posted March 16, 2011 Gm Timing Belt £16.62 (OMOC Memeber Cost £12.11) Gm Water Pump £50.77 (OMOC member Cost £43.15) Gm Water Pump Seal £2.69 (OMOC Member Cost £2.30) Gm Water Pump Bolts, 3@£1.09 eac (OMOC Member Cost £0.95 each) Gm Dissy belt £6.40 (OMOC Member Cost £5.44) Pump and Dissy Belt only avaliable from Opel All prices subject to VAT @ 20% Cheers Andy Wow, thanks guys, I have sourced GM belt, Andy do you have the part No's for Pump Seal, bolt's and GM dizzy belt, have sourced a QH water pump. Will then pop to my local GM parts shop! Thanks again Link to comment Share on other sites More sharing options...
