Fuel Pump Relay
Roy
Hi, not sure if this is the same as a manta one but I'm running a 2.2 Carlton injection system on my manta and I think the relay has gone. She won't start and the pump does not do its little squirt when the ignition goes on.
I tested the power to the pump and the pump itself which seem fine so it must be the relay. Has anyone got one?
Drop me a PM please
thanks
Roy
Drop me a PM please
thanks
Roy
Before you do that, have you tried bridging fuse number 7? I did that mistake & sent the relay I just bought back to a shop in cornwall. GM6 spares or something like that. Try him if all fails. I found him on flea bay & should come up if you google it maybe?
Hi mate you could try wiriing it direct as a temp measure?bridge across terminals. if you cant get a relay from your local breakers try an omega fuel relay which is fitted under a large cover near the battery
Edited by cop
Hi, i tried wiring in a switch but it just floods the engine no matter how careful I try and be. I have a GTE buried in another lockup I'll see if that relay is the same, if not I'll be hunting another.
Looked at GM6 spares in the past, he'd probably want £100 for a second hand one!
Thanks for the suggestions though :thumbup
Well my exclusive had a siemens version which fits and the car now runs. I still need one though!
I also found this on the internet which has all the same pin numbers.. Might be useful..toolboxshop quoting £34 plus vat
0-723-42, Durite fuel pump relay
Fuel pump relay replacement type for Lucas, Citroen and Cartier styles,
Terminals: seven terminal type,
With fixing bracket,
Sold in single packs,
Quality replacement for:
Lucas: FDB506,
Citroen: 91541882, 1452 05, 145205,
Cartier: 02474,
Valeo: 2474.
