marius Posted May 12, 2011 Share Posted May 12, 2011 Found this on the net , maybe it would be useful for someone Front: Spring type: Linear coil spring Material: Spring steet, hot rolled, ground, surface condensed Wire guage: 12.15mm / 0.48 inches Outer diameter: 116.3mm / 4.58 inches Inner diameter: 92mm / 3.62 inches Spring height fully compressed: 127mm / 5.0 inches Spring height unloaded: 376mm / 14.80 inches Spring height at designed load position (432kg or 952 lbs): 203mm / 7.99 inches Spring rate at designed load position: 25kg/cm or 140 lbs/in Wheel rate at designed load position: 12kg/cm to 13kg/cm or 67lbs/in to 73lbs/in Rear: Spring type: Progressive coil spring Material: Spring steel, hot rolled, ground, surface condensed Wire guage at spring center: 12.83mm / 0.51 inches Wire guage at spring ends: 0.47mm / 0.37 inches Outer diameter: 120mm / 4.52 inches Inner diameter: 94.34mm to 101.06mm / 3.71in to 3.98 in Spring height fully compressed: 102.5mm / 4.04 inches Spring height unloaded: 325mm / 12.80 inches Spring height at designed load position (310kg/683lbs): 193mm / 7.60 inches Spring rate (rate from kurb weight to gvwr): 22.5kg/cm to 38.1kg/cm or 126 lbs/in to 215lbs/in Wheel rate (rate from kurb weight to gvwr): 16.3kg/cm to 29.4kg/cm or 91lbs/in to 165lbs/in Quote Link to comment Share on other sites More sharing options...
rutts Posted May 12, 2011 Share Posted May 12, 2011 just what i needed. thanks for information Quote Link to comment Share on other sites More sharing options...
611 Posted May 13, 2011 Share Posted May 13, 2011 If you ever need any springs making up i had some lowered ones made by these guys http://www.springcoil.co.uk sent in my old ones that we uprated and not lowered and got back a nice set of lowered ones but to the same rating as the old ones £95 all in. Not on the car yet, so will find out what they handle like when its all going Quote Link to comment Share on other sites More sharing options...
marius Posted May 13, 2011 Author Share Posted May 13, 2011 I found some springs Quote Link to comment Share on other sites More sharing options...
