Shug Posted June 25, 2011 Share Posted June 25, 2011 Any ideas how to get the bonnet open on an A series when the cable has gone on release mechanism? I'm thinking of burning it open with 5 litres of petrol.... Quote Link to comment Share on other sites More sharing options...
garymanc Posted June 25, 2011 Share Posted June 25, 2011 cant you just yank the cable as far down as you can reach,use to do this scrapyard hunting back in the day. 5 litres of petrol can you afford to spend that much Quote Link to comment Share on other sites More sharing options...
paulmanta Posted June 25, 2011 Share Posted June 25, 2011 A challenge....I would try and raise the car up at the front as far as I could and try to reach up into the engine bay from underneath. Two areas to target here, one is the hinges, they might be accessable from below, if you get them off then you might be able to lift the bonnet up enough the reach the latch release. The second target is the latch, its up above the middle of the gearbox as you know but you might get at the release mech if you have long arms and can get past the starter. I had to do a GTE yesterday, I undid the two 13mm bolts that held the latch in, they were easy to get at in comparison to the A. Quote Link to comment Share on other sites More sharing options...
Shug Posted June 26, 2011 Author Share Posted June 26, 2011 It's open!! All you need is to mention it to someone who knows a time served panel beater who has every tool under the sun and jobs a good un!! Stroke o luck that one! Quote Link to comment Share on other sites More sharing options...
