manta88 Posted October 25, 2011 Share Posted October 25, 2011 I have just started a rebuild on my 16 valve engine and i checked the engine number ,it reads 01 00 00 01, is it a recon engine or have i got one of the first C20XE engines ?,i was told the engine was originally out of a Cav GSI many years ago. Quote Link to comment Share on other sites More sharing options...
Christ Posted October 25, 2011 Share Posted October 25, 2011 Sure you're reading the right number mate? It's stamped on the flange the bell housing bolts to Should start with 20XE........ Quote Link to comment Share on other sites More sharing options...
manta88 Posted October 25, 2011 Author Share Posted October 25, 2011 I got the number from the top surface of the block ,at the back right hand side ,am i looking in the wrong place. Quote Link to comment Share on other sites More sharing options...
johnboy Posted October 26, 2011 Share Posted October 26, 2011 Don't know what that number is but if you look on the bell housing flange on the exhaust side of the block it should be stamped there, it'll probably be rusted over and hard to see, wd and sand paper usually brings it back. Quote Link to comment Share on other sites More sharing options...
andyc Posted October 26, 2011 Share Posted October 26, 2011 Yeah the number should be on the bell housing webb exhaust side. If the motor is a non cat engine then the number will start 20XE* If its a cat engine then the number will start C20XE. If you have anything diffent from the above then you have a recon motor and the number thats beeb stamped on the block will only be of any use to the people who built the motor Cheers Andy Quote Link to comment Share on other sites More sharing options...
upk Posted October 26, 2011 Share Posted October 26, 2011 the number you refer to on the block top surface is most likely the bore measurement expressed in code as used on the engine assembly line! Quote Link to comment Share on other sites More sharing options...
manta88 Posted October 26, 2011 Author Share Posted October 26, 2011 Thanks chaps ,found it under some rust and a few layers of engine paint Quote Link to comment Share on other sites More sharing options...
