Posted
Hi I have a very good manta a axle with it's torque tube and a brand new ZF LSD
Hello Ant,
Is the LSD fitted in your Axle yet or does it need fitting? There's a couple of different ZF LSD's, so if you can find a number on its casing, I'll be able to tell which ratio diffs it would suit or what you have fitted. Is the complete diff brand new, or just the internals? This sounds like a bargain for someone....Even if it's in bits... Luke.
Posted
It's a completely brand new diff which is fitted in the axle the ratio is 4.7:1
I bought it for my chevette but I needed a manta b axle, with hs group 4 arches it was to narrow
