Dave Stampy Posted January 18, 2012 Author Share Posted January 18, 2012 I'd also like one of those quick shift plates my only problem is the gearstick shaft thing snapped off mine by th pins will this replace it its not ike a shaft more of a flat metal thing? Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 19, 2012 Share Posted January 19, 2012 You're ok as long as you have the "stub" that sticks out of the back of the omega box. If you unbolt the big flappy plate thing that holds the stick, you'll see where the shifter goes into the back of the omega box. Just behind where it enters the box casing there is a metal block with two pins through it. I need up to and including that block, but nothing behind it. The clevis on my shifter fits onto the rear pin on that block. PS just read the full thread. Re. Ford type 9 boxes, a standard type 9 box is no stronger than a manta 1800 one, in fact probably weaker. I have broken an equal number of both I would guess! The benefit of the type 9 is that you can get lots of aftermarket gearkits for them, rated up to 275hp, at which point the casing is at its limit. (even reinforced ones) PS will get onto sorting a batch of these shifters this weekend.....not enough hours in the day! Will get the bearings and clevises ordered! Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 20, 2012 Share Posted January 20, 2012 Right have looked into it all and it will be about 3 weeks to get some shifters sorted, hope that's ok!? Quote Link to comment Share on other sites More sharing options...
opel2000 Posted January 20, 2012 Share Posted January 20, 2012 a standard type 9 box is no stronger than a manta 1800 one, in fact probably weaker. You know what Nat, that was always my impression, but never actually having had experience of them I could never really comment. Also sounds like you may be getting busy on the fabrication front, if I wasn't so tied up at weekends I'd pop over and cobble those up for you mate. Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 25, 2012 Share Posted January 25, 2012 We are Clive!! We're starting to get a little list if things on the "jobs for Clive" list and then we were going to abduct you and drag you down here to do em!!! Quote Link to comment Share on other sites More sharing options...
opel2000 Posted January 25, 2012 Share Posted January 25, 2012 Heck! sounds like I may ned to take some time off on the sick. Quote Link to comment Share on other sites More sharing options...
