Dave Stampy Posted February 14, 2012 Share Posted February 14, 2012 Long story short all the bearing fell out tried everywhere no luck someone on here must have changed them? May possibly need a steeribg shaft if there is a spare aboutor if anyone knOws how to change the white pins? Link to comment Share on other sites More sharing options...
andyc Posted February 14, 2012 Share Posted February 14, 2012 Hi Dave Top coloum bearing is avaiable from Vauxhall as they are the same as the ones used on mk2/3 cavaliers The bottom bearing is Manta only and as far as i know isn't available anywhere but if you have a hunt round on german ebay you might get lucky. As for the white pins on the coloum then they are not repairable as the are designed to break in tn accident which means fitting another coloum if you can fins a secondhand one, this might be a good point to look into electric power steering . If, from your other posts you are having a sump made then should be able to work it so you can put the rack back in its propper place and re-fit an uncut cross member. Cheers Andy Link to comment Share on other sites More sharing options...
Dave Stampy Posted February 14, 2012 Author Share Posted February 14, 2012 Ok cheers for the info , I do have a steel sump and am reaLly starting to consider to move the rack back ect Its just one of them things going back ob your work but it will be for the best I suppose, and yea I think I will do the corsa b steering mod thank you. If any one knows where to get these lower bearing would be great many tanks. Link to comment Share on other sites More sharing options...
611 Posted February 18, 2012 Share Posted February 18, 2012 Hey dave Dr manta does the lower one for 22 euros, its part number 90023940 might be worth trying vauxhall? Lager unten Lower bearing Kunststofflager Lenkspindel unten Lower plastic bearing steering spindle Preis / Price: 22,00 € Best.Nr. / Order-No.: 03320006 Details & Bestellen Details & Link to comment Share on other sites More sharing options...
Dave Stampy Posted February 23, 2012 Author Share Posted February 23, 2012 Ahh nice 1 cheers, I got the upper bearings off andy c and was about a 10a including p+p for future prefrence. Link to comment Share on other sites More sharing options...
