druid Posted April 6, 2012 Share Posted April 6, 2012 Hi guys I decided to change a leaky rocker cover/camshaft cover gasket on my '85 1.8S Berlinetta Coupe and discovered that the housing bolted to the underside has a whacking great hole in it! I looked inside the cam housing and no alloy fragments inside so perhaps a previous owner broke something and did not change the broken housing. Close up showing part number So a bit of advice: 1) does anyone have a spare housing they'd like to sell me quickly (can do paypal asap)? The part number is: 90128373 with 11120122 written underneath 2) Can I simply pop the broken mount in the car and run it as is until I get a new mounting i.e. is it safe to run the with the current broken mounting car as I'm a bit stuck at the moment? 3) what would have caused the breakage? I have owned the car for a couple of months and done about 600miles no probs - car hasn't missed a beat. Thanks for any help or advice. Quote Link to comment Share on other sites More sharing options...
rusty321 Posted April 6, 2012 Share Posted April 6, 2012 i think i should have one, i'm off up the workshop in a bit i'll have a look and get back to you. Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted April 6, 2012 Share Posted April 6, 2012 If Russ hasn't then I've definitely got one I can take off this afternoon for you Quote Link to comment Share on other sites More sharing options...
druid Posted April 6, 2012 Author Share Posted April 6, 2012 Thanks Russ and Rob. I would be indebted to either of you if you could get one in the post for me tomorrow (saturday) then I would have my wheels back for Tuesday with a bit of luck. I could paypal (as 'gift') the money asap just let me know what you want inc. postage. Russ if I haven't heard back by 6pm tonight, would it be OK to deal with Rob? Rob, are you OK with this. Complicated dealing with 2 of you at once, but great to have you both step forward in my hour of need! Quote Link to comment Share on other sites More sharing options...
paulmanta Posted April 6, 2012 Share Posted April 6, 2012 It is only a flame trap casting, the crank case vents from the top of the rocker cover and it has to have a baffle under the pipe or in cases of very worn engines oil/flames could come out and go unchecked into the inlet and carb. I suspect the thing was damaged at the factory and has been in the car forever like that, or a previous owner tried to clean out the metal gauze that lives in this casting and dropped it, you need to put a good casting back and if there is a metal gauze pop that in as well. It is not structural, nor does it represent a big risk driving with the hole in it but if it were my car I would want it to be right and have it fitted. Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted April 6, 2012 Share Posted April 6, 2012 No worries mate, that's fine with me. To be honest as far as I know the car will run fine without it, looks like it already has for thousands of miles, it's just a housing for the gauze oil filter on the crankcase ventilation system. All it means is that you may burn a little bit more oil vapour through the carb than you would if the gauze filter was in place, it's certainly not unsafe! Quote Link to comment Share on other sites More sharing options...
druid Posted April 6, 2012 Author Share Posted April 6, 2012 It is only a flame trap casting, the crank case vents from the top of the rocker cover and it has to have a baffle under the pipe or in cases of very worn engines oil/flames could come out and go unchecked into the inlet and carb. I suspect the thing was damaged at the factory and has been in the car forever like that, or a previous owner tried to clean out the metal gauze that lives in this casting and dropped it, you need to put a good casting back and if there is a metal gauze pop that in as well. It is not structural, nor does it represent a big risk driving with the hole in it but if it were my car I would want it to be right and have it fitted. Thanks fella. I'm like you and like to have things 'right' so i don't want to re-fit the old broken one and would rather wait a couple of days to fit a decent spare that Rob or Russ can suuply. No worries mate, that's fine with me. To be honest as far as I know the car will run fine without it, looks like it already has for thousands of miles, it's just a housing for the gauze oil filter on the crankcase ventilation system. All it means is that you may burn a little bit more oil vapour through the carb than you would if the gauze filter was in place, it's certainly not unsafe! Thanks Rob. If I don't hear from Russ by 6pm I'll take your housing if that's OK? Do you reckon you could bang it in the post tomorrow (big ask I know, but would like to re-fit on Tuesday and can't see the sense in fitting the duff one and damaging the new gasket to change it over to a new housing 3 days later). Thanks fella Quote Link to comment Share on other sites More sharing options...
druid Posted April 6, 2012 Author Share Posted April 6, 2012 Thanks fella. I'm like you and like to have things 'right' so i don't want to re-fit the old broken one and would rather wait a couple of days to fit a decent spare that Rob or Russ can suuply. Thanks Rob. If I don't hear from Russ by 6pm I'll take your housing if that's OK? Do you reckon you could bang it in the post tomorrow (big ask I know, but would like to re-fit on Tuesday and can't see the sense in fitting the duff one and damaging the new gasket to change it over to a new housing 3 days later). Thanks fella Hi Rob Haven't heard from Russ so if you've got the housing I'll paypal you the dosh. I've sent you a pm. Quote Link to comment Share on other sites More sharing options...
druid Posted April 6, 2012 Author Share Posted April 6, 2012 i think i should have one, i'm off up the workshop in a bit i'll have a look and get back to you. Hi Russ Rob has sorted me out now but thanks very much for offering to help. You're a gent! Quote Link to comment Share on other sites More sharing options...
