davo Posted September 18, 2012 Share Posted September 18, 2012 which calipers do i need that bolt straight on to a manta b to work with the redrilled audi discs. i know there are 16v ones but which model or better still anyone got the part number cheers Quote Link to comment Share on other sites More sharing options...
Shug Posted September 19, 2012 Share Posted September 19, 2012 You need ones from a Vauxhall that had 256mm discs. Cavalier, some astras, early low spec vectras with 4 stud hubs. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted September 19, 2012 Share Posted September 19, 2012 As Shug says there isn't really an easy answer to which calipers. They were fitted to astra mk2 mk3, calibra, cavalier mk2 mk3, and a few early vectra's with 4 studs Plus as they're such a common upgrade for vauxhalls there are a lot of them that have been fitted on nova's and corsa's. The thing is vauxhall swapped the brake specs from early cars to later ones on most of the models so its hard to do a definative list The only model i know that they were fitted to as standard for the whole run was the mk2 astra 2.0 16v which is why they are known as redtop or 16v calipers Basically they need to be the ones for 256mm discs and anyone selling calipers should know what size disc they came off. Quote Link to comment Share on other sites More sharing options...
davo Posted September 23, 2012 Author Share Posted September 23, 2012 Nice one Thanks for the advice chaps Quote Link to comment Share on other sites More sharing options...
