Stev0 Posted October 10, 2012 Share Posted October 10, 2012 Greetings, a friend of mine is installing a C20XE into his Manta A but he's having difficulty with fitting it as the sump gets in the way of the rest of the car and he can't get the motor in... Has anybody else experienced this problem? if so, please advise how to go about solving the issues with the sump. thanks Quote Link to comment Share on other sites More sharing options...
Jason_d Posted October 10, 2012 Share Posted October 10, 2012 You need to find a manta big wing sump, getting pretty hard to find now. Quote Link to comment Share on other sites More sharing options...
Stev0 Posted October 10, 2012 Author Share Posted October 10, 2012 by that i'm assuming you're refering to the manta B... as the A's never had family II motors from the factory... do you have pics?? is there another way? Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted October 10, 2012 Share Posted October 10, 2012 Yep, you either want a sump from a Manta B 1.8, or you'll have to cut and weld yours to fit! Quote Link to comment Share on other sites More sharing options...
monzta Posted October 10, 2012 Share Posted October 10, 2012 B series sumps are identical to the A series one. So as written above, you need one from a 1,8 Manta B series car. Otherwise welding one is an option, and if doing so make sure that you give it plenty of volume, and make those plates while you are at it. Don´t know what they are called in English but a direct translation is "wave-stoppers" Makes sure the oil doesnt end up in only one side of the sump when going at it one the roads, or on a track 1 Quote Link to comment Share on other sites More sharing options...
Stev0 Posted October 11, 2012 Author Share Posted October 11, 2012 (edited) B series sumps are identical to the A series one. But is the sump flange and bolt pattern the same for CIH and OHC motors?? because none of the A's came out with the OHC type motors, and my mate wants to fit that (C20XE lump is the same as the OHC 8v's)... I know their bellhousing bolt pattern is NOT the same, not sure about the sump but i doubt it.. So welding is basically the only way? i suppose he also needs to watch out for removing too much oil capacity from the sump while doing so.. Don´t know what they are called in English but a direct translation is "wave-stoppers". they're called "baffle plates" stops the oil sloshing around the sump (and away from the pickup) around corners and under acceleration/braking.. Edited October 11, 2012 by Stev0 Quote Link to comment Share on other sites More sharing options...
monzta Posted October 11, 2012 Share Posted October 11, 2012 Manta B 1,8 is a OHC mate not a CIH, so will fit directly in as fitment around the front member of the A and B series cars are identical So best choice would definatly be a Manta B 1,8 sump. Quote Link to comment Share on other sites More sharing options...
andyc Posted October 11, 2012 Share Posted October 11, 2012 If your fitting a 16v C20XE to the A series then you either need a B Series 1.8s Alloy sump or make a sump using an old OHC Sump, forget about the CIH sumps. Will also need a Gearbox from a 1.8s as well.as the CIH box will not fit the C20XE Andy Quote Link to comment Share on other sites More sharing options...
Stev0 Posted October 11, 2012 Author Share Posted October 11, 2012 (edited) thanks andy and monzta, yeah he's got an R25 box to go with the motor, but the gearbox is huge and doesn't fit into the tunnel so nicely... were there any getrag RWD gearboxes with the OHC bellhousing pattern that fit into the tunnel nicely? later rekord models perhaps? Edited October 11, 2012 by Stev0 Quote Link to comment Share on other sites More sharing options...
andyc Posted October 11, 2012 Share Posted October 11, 2012 Yes you will need a gear box from a 1.8s as this is the same size as the CIH box but with a different bellhousing pattern to fit the OHC engine Andy Quote Link to comment Share on other sites More sharing options...
monzta Posted October 11, 2012 Share Posted October 11, 2012 It will still be a tight fit though and you will have to change the console for the interior as the gearleaver will be placed further back inside the car Quote Link to comment Share on other sites More sharing options...
Stev0 Posted October 12, 2012 Author Share Posted October 12, 2012 monzta i hear you can modify the gearbox so that the gearstick still comes through the same hole: http://tekenaar.opelgt.com/getrag/getrag_240_mods.htm i'm thinking maybe its a good idea to have the shorter gear level further back, modifying the centre console isn't so bad, but i'll cross that bridge when i get to it.. Quote Link to comment Share on other sites More sharing options...
399Road Posted November 4, 2012 Share Posted November 4, 2012 He'll probably need to get an Exhaust manifold custom made too, as the RWD Escort and Manta 16V conversion Manifolds won't fit an A.series car. The Manta A's front Anti roll bar runs behind the cross member and gets in the way of the usual 16V conversion Manifolds. Quote Link to comment Share on other sites More sharing options...
