611 Posted January 26, 2013 Share Posted January 26, 2013 Just thought i would post this here as the last one was under free stuff. Anyone looking for Silicon Hoses should definitely get in touch with JS performance. They have just made me a set for my A series. The top one is the standard top hose that they make and the bottom one they have enlarged the lower outlet up to 44mm as im using a Summit Racing rad in mine and the top outlet is the same as a standard Manta one but the lower is much bigger. Im also routing my hoses in a different way for the heater hoses so i don't have the standard ones but ones that are just the right setup from a Lotus Cortina! I will be sending them the heater hoses from mine so they can make up a set if anyone out the with an A series needs any. Not sure what they will charge but the Cortina ones were £20 each, which i didnt think was too bad. Here is a picture of the hoses and as soon as they are on the car i will add an updated picture. Andy 1 Quote Link to comment Share on other sites More sharing options...
robah Posted January 26, 2013 Share Posted January 26, 2013 Glad you like the equipment Andy. Like I have said before, top guys, top quality, top service Rob Quote Link to comment Share on other sites More sharing options...
